Checking In of "Out-of-date" files
  • February 14, 2013
  • 2 replies
  • 1206 views
Intralink 3.4
I want to change the settings to "FALSE" I don't want users to be able to check-in files that are out-of-date. I assume it would be configured under "Roles" but I do not see it?
[cid:image001.png@01CE0A93.AB700A80]
Can anyone point me to where to change this?
Thanks in advance,
[Description: cid:012445618@15012007-1FE4]
That should be set by the Object Action "Forced Check-In to same branch" in Roles.
Oh, it is kind of hidden in the Pro/I help but if you search for "Object and Folder Actions" you can find the full role action table.
