Classification explorer doesnt show the tree structure
  • November 30, 2023
  • 4 replies
  • 3053 views
Is there any specific license required to view the tree structure in classification explorer?
We get a blank list as below for the tree structure.
Best answer by MarianaSousa
I was able to find the "error". Forgot to set the Classification Attribute in the Part with the Namespace.
Thanks anyway
HelesicPetr
Hi @AP_10483126
I don't think there is a license issue.
Three can be ACL access rule issue.
Based on the picture, the object is loaded to the table, but the information from object is not shown in the table.
First I would try clean a explorer temporary files and cache and also restart Windchill with cleaning the server cache, temp , and so on
PetrH
What ACL needs here you think ?
HelesicPetr
Hi @AP_10483126
First You can test WTObject with full control to one user who can not see the values.
If it helps, then it is ACL issue, if not you then it is different issue and you need to keep searching.
log files, debug settings and so on.
PetrH
What is the status of Solr? Classification will not show up if Solr is not running or the Index is not created.
yes its up and running
avillanueva
23-Emerald I
23-Emerald I
November 30, 2023
https://www.ptc.com/en/support/article/cs312732?source=bloop
Check that the user has right licenses and is not also part of View and Print license group.
yes wtparts link license is there but still doesnt work
avillanueva
23-Emerald I
23-Emerald I
November 30, 2023
Is this brand new install and is experience same for all users? There is a whole bunch more articles here:
https://www.ptc.com/en/support/article/CS365850?source=search
Are there parts classified?
