Clear Cache Windchill
  • May 4, 2023
  • 6368 views
Good morning ,
would have any way to clear this cache of automated machines? any script that I can put in the GPO or in the machine itself even if I do this every week?
Best answer by MS_Santos
Do you have a ready-made bat or script to do this because when it reaches a certain size, it starts to slow down, or if you can increase it, that would be cool too.
avillanueva
23-Emerald I
23-Emerald I
May 4, 2023
This the workspace location where is downloads are and where it saves files the modified files. when you say automated machines, like a CAD worker? Yes, you can whack that and I typically whack the .wf folder since the CAD worker can rebuilt the server registry.  If this is a user's machine, no, do not delete that folder as it would lose their local work that is not checked in.
MS_Santos15-MoonstoneAuthor
hello everything is fine
I believe I didn't explain it directly, I need some script or something that every week it clears after a while it gets very slow, today we do it manually
is this for end user machines? weekly clearing of the cache seems drastic. is the cache folder located on the local machine and not a network drive?
