Clear Cache Windchill
  • May 4, 2023
  • 6368 views
Good morning ,
would have any way to clear this cache of automated machines? any script that I can put in the GPO or in the machine itself even if I do this every week?
Best answer by MS_Santos
Do you have a ready-made bat or script to do this because when it reaches a certain size, it starts to slow down, or if you can increase it, that would be cool too.
avillanueva
23-Emerald I
23-Emerald I
May 4, 2023
This the workspace location where is downloads are and where it saves files the modified files. when you say automated machines, like a CAD worker? Yes, you can whack that and I typically whack the .wf folder since the CAD worker can rebuilt the server registry.  If this is a user's machine, no, do not delete that folder as it would lose their local work that is not checked in.
MS_Santos15-MoonstoneAuthor
hello everything is fine
I believe I didn't explain it directly, I need some script or something that every week it clears after a while it gets very slow, today we do it manually
Like @avillanueva and @ScottMorris said, the size of the cache is not the likely cause of the slowness. It's common practice to wipe the cache folders on CAD workers but on user systems I only ever do it when the cache needs to be rebuilt (cache corruption, Creo to non-Creo cross contamination). You can create a start up script that starts with a clean cache every time or you can create a clean up .bat that runs on a schedule through the OS... it will delete data though.
What sort of slowness are you seeing?
One thing that worked for us to improve speed was adding anti-virus exclusions to particular cache folders (CS50545).
