When converting Excel file into XML file, Instead of constraints related information there is some 14 digit number in constraints value for example - CONSTRAINT= 93716108618800 is in XML file. What is this value refers to?
Constraints are objects in the database. I would suspect that this is just a generated ID that its using for the load to make sense of unique constraints when importing. I am guessing this is a random number.
