Yesterday, we upgraded the system to 10.2 M010 from 10.0 M040. it was successfull and then we clustered it
2 slave and 1 master then configured load balancer in slave 1
later, in the evening, we had performed some testing, it was working fine but next day morning ,that is today, all of the sudden
contents were not visible, after couple of refresh, it works and then couple of refresh it will not work, it was very unstable, but after completion of upgrade we had tested it, all functionaity we could able to perform, like check in check out create epm doc , replica and publishing and al other things were working..
above test was made with cluster configuration ( 2 slave and 1 master )
morning,, it was behaving weiredly .. no content to see from cabinet page of user and search was showing blank result though objects were there with that search string.,
does any body faced such problem, if yes what solution you adopted., please share.
Now, we have removed load balancer and running it in single slave , so it is working fine , as normal but with slave 2 and load baancer it is not working.
Same load baancer configiuration was applied which ws used in 10.0 before upgrade with ittle changes like path , like that ...
I see you mention that when you remove the load balancer and directly connect to one of the slaves, Windchill works fine. Have you tried directly connecting to both slave nodes, or did you only test one? If there is an issue with one slave node and not the other, then the issue would appear intermittent, like you describe. The issue would only be seen when the load balancer forwards your request to the problem node.
