Custom Utility - Delete representations in bulk
  • March 24, 2013
  • 701 views
Hello ,
Scinerio
Solutions:
A utility was developed to clear such representations; which efficiently removes the unwanted representations and clears the clutter.
There is even a provision to delete, "selective" or "all" representations.
Tested rnatrajan@mail.com
Hi @rnatrajan ,
Is there any utility to delete representations based on selective object numbers? Can you share that?
avillanueva
23-Emerald I
23-Emerald I
February 6, 2025
Yes, see this page: https://www.ptc.com/en/support/article/CS211115?source=search
This adds actions to the search results which will then allow you to deleted based on what you search on. Also please avoid posting to very old messages. You should start a new post instead.
