Customer Part Numbers
  • June 29, 2020
  • 1439 views
I have parts saved in Windchill and I have a parameter that stores the customer's part number.  However, sometimes there are cases where the same part is used for many different Customers.   Is there a good way to associate a list of customers who use the part and the given part number that they have assigned our part?  There is something similar with Supplier Part Management.  Is this a good option?  Set up the customer as a supplier?
After I do this is there any way to create a query of this data so that I could retrieve a list of customers and their corresponding part number for a single part?
Hi
I thing the answer to your question will depend on the complete usecase. You have expressed only the need to tag a part with it's customers but you haven't said anything about how this information is used in your full process. There are many options I see that can be used here :
 - Multivalued attribute (this can be done using type manager)
 - Option assigned to parts
 - Configurable links
 - Effectivity by context (Each customer is an effectivity context)
I can elaborate more on each option, but in summary it'll depends if you need more details related to your customer, if you need to search by customer and if you need to filter your product by customer.
Regards
Kamal
kamal@pasi-consulting.com
