Customize BOM Type values in MPMLink
  • July 11, 2018
  • 3 replies
  • 3577 views
I am new to MPMLink, so this might be something basic. My requirement is to add some custom types for the BOM Type in the drop down menu (which by default has the values Costing, Production & Testing). This is while creating a new Downstream branch from the Manufacturing Associative Part Structure Browser. The BOM Type is not an object I believe, could not find anything so far. Please help or any clues how to proceed further would be great.
Best answer by Casey_Swain
They are modeled, so you can't extend them from Type & Attribute, but as follows:
  • Use enumCustomize to update:
  • <WT_HOME>/codebase/wt/vc/views/Variation1RB (BOM Type)
Overview from Online Help
Hi @sbegum-2 ,
To change legal value list I would do something like this: Organisations -> Utilities -> Type and Attribute
Management -> Select Part -> Attributes -> BOM Type -> Right Mouse Button -> View Info - > Constrains -> Legal Value List
To set default BOM Type value in MAPSBManufacturing Associative Part Structure Browser) go to:
Organisations -> Utilities -> Type and Attribute Management -> Select Part -> Layouts -> MAPSB Structure Transformation Layout
sbegum-21-VisitorAuthor
Thank you @Casey_Swain & @GregoryPERASSO for the help!
Keep spreading the knowledge.
Cheers!
Shenaz
have you added custom view, where the new bom type can be transferred, since i am facing issue after addition of new BOM type i am not able to set different custom views which i have, where i am only able to add the selected EBOM view and manufacturing default OOTB view
