DataUtility for attribute display
  • September 9, 2014
  • 2199 views
Hi.
I have datautility to specify view for soft attribute.
I configured it by site.xconf
<Service name="com.ptc.core.components.descriptor.DataUtility" targetFile="codebase/service.properties">
<Option serviceClass="MyDataUtilityClass"
requestor="java.lang.Object"
selector="attributeInnerName"
cardinality="duplicate"/>
</Service>
This datautility works fine on "Type Attributes" panel in "Details" tab.
But it does not work on "Attributes" tab in "Structure" tab.
Why?
How can this problem be solved?
Thanks.
Best answer by LoriSood
If you edit the layout in Type and Attribute Management you should be able to right-click on the attribute in the layout. Within the properties window you can specify the data utility to use for that attribute in that layout.
LoriSood23-Emerald IAnswer
23-Emerald I
September 9, 2014
Use the selector name as specified in site.xconf as data utility id in the properties window.
Kaushik
