Dear Experts,
Is there a way to control the filters which is available in the Structure tab using date effectivity i.e say for instance we have two versions of a WT part ABC 1.1 and ABC 2.2, for the version ABC 2.2 date effectivity has been applied from 30-Aug-2015 when a normal user logs in to Windchill on 20-Aug-2015 and navigates to the structure tab by default the latest version would be visible (which is ABC 2.2) this happens because by default the filter applied is always latest, can we change this configuration by some means so that the user can see the latest information of a product only on a valid date ?
I hope I am clear if not please let me know so that I can explain the scenario even better
Athmanand
