Duplicate or save as objects in Windchill
I am facing a unique problem and unable to solve it. Would appreciate if someone could help.
Ideally the wt part, drawing file and CAD part file all should have the same "Number", "Name" and "File name" in PDM windchill. Its a kind of best practice developed in our company. We also have autogenerated numbers for new files enabled. So if we create a new part, automatically a number is assigned and related drawing file and wt part file with the same number is created
Now with that background in mind, i have a certain part file and its related drawing file. I need an exact copy of the same but with very minor change (maybe a small dimension change). I dont want it to be a family table but want it to be a separate file by itself. So the new required part should have a new number and this same number should be assigned to its related drawing file and wt part file. So if i try to "save as" the drawing file with new auto generated numbers for all the related parts, it does the job BUT now the new drawing file, its related part file and wt part file DO NOT have the same number. Each one has been assigned a different new number.
I try to rename the drawing name to have the same name as the part file but it says already a drawing file with the name exists so cannot rename.
So i try the reverse - to rename the part file name with the drawing file name but again the same problem, it says already a part file with the same name exists so cannot rename.
So i try another option - back up the drawing file to local system hoping to rename them locally "outside" of PDM and then put them back in. But it would not allow me to rename the file, giving a message saying "it is not recommended to rename files managed by pdm outside" and thus cancels the rename command.
So i am stuck with this problem with no solution for now.
Does anyone know the best option here?
Best regards,
Mohan
