EPMDocument subtyping
Is this possible and let me know if anyone had success.
Creating two subtypes at site level to achieve the end goals 1 and 2. Mainly to drive separate list of attributes and layouts on each subtype.
1. EPMDocument subtype1 - This should be available to for org1,2,3,4,5 creo users.
2. EPMDocument subtype2 - This should be available to only for org 6 creo users.
First started defining single subtype at site level and then followed steps documented as per this article https://www.ptc.com/en/support/article/CS41665. Could't force Creo/WGM to use epm subtype to create first CAD Document. I don't see options in this article to proceed to create CAD Document templates when not having single CAD Document in system using custom subtype.
