Error in Creating user in windchill.
  • December 3, 2014
  • 2 replies
  • 4226 views
I created some 3-4 users in windchill by using following procedure:
  • Windchill Administrator Login> Site> Utilities.
  • Principal Administrator> New User> Created User Profile> Click OK.
But when I tried to add the users in Product teams, those users were not available in search list. Although these entities are present in Windchill Directory Server Control Pannel.
So I deleted those users & once again tried to create them, but now I am getti an error "Username is not Unique".
I am unable to find the cause of both 1) Why users were not available in search list? 2) Why user is not getiing created again?
Ensure you provide some email address for the users to be listed for the searches. Also, did you deleted the users from both Windchill and Directory server.
~Syed
Hi Syed,
I already did that. But no use. Please suggest me any alternative solution.
Tanvi
Tanvi,
Have you been able to successfully create users and add them to the product team? Let us know if you're still having any trouble with your users.
When creating new user in windchill I am not able to set attributes. Please find the Image. help me to resolve the issue.
Manikandan.
I had the same issue. It tortured me a whole week. It happened after I installed CPS12.
The issue turned out to be related to Internet Explorer set to run as "Microsoft Edge" by default.  Well, Windchill is not compatible with Edge. So change that hidden setting to Explorer and the problem is fixed.
1/ In IE, click on the setting wheel to display the Help Menu.
2/ Click on "F12 Developer Tools"
3/ Click on the "Emulation" tab
4/ Change the "Document mode" drop down to the highest number listed instead of Edge.
5/ Shutdown and restart Windchill to go back to Create New User.
