Error message when logging into Winchill server in Creo software
Aurelian
When connecting to a server in Creo software, a pop-up prompt appears:The winchill license for server XXX is insufficient, and the connection to the server is denied.
Is there a problem with the license? However, I have no problem logging into Winchill in the browser.
Does any friend know how to solve it? thank you!
Fadel
23-Emerald I
(To:Aurelian)
This is most likly expected .
My guess is that you are login with wcadmin with no license assigned this works for windchill but not in creo .
take a a look at https://www.ptc.com/en/support/article/CS282719
Another cause is that when using an incomatible windchill/creo pair https://www.ptc.com/cn/support/article/CS172786
Fede
Fadel
23-Emerald I
(To:Aurelian)
Fede
Aurelian
(To:Fadel)
Yes , you are right!As you said, it's a licensing issue
The issue has been resolved. The relevant technical article has been recorded in the PTC technical support knowledge base, with article number<CS290400> https://www.ptc.com/support/article/CS290400
Aurelian
(To:Fadel)
Thank you again for your answer
