Export and import wtpart structure with creo view representations
we need to copy a large WTParts structure including associated Creo View representations and related IBAs, between prod to a test system. The user inter face based solutions crash due to the dire size of the structure.
Which are the possibilities to extract the structure in Windchill backend, which should resolve into an XML load file + Creo View files on disk, which we can then import into the target system?
On top of this, in the extracted XML we have the need to make small adjustments, for example add a prefix to the numbers, and small things. Therefore we need some kind of XML that we can modify.
/Gustav
