Check out page 59, File Content Migration Settings, of the Install and Usage guide. I have never used this tool but WC2WC should be straight forward that the tool handles this transfer of file content.
Are you using the Windchill Bulk Migrator? https://www.ptc.com/en/support/article/CS323926?source=search
Assuming you are going from one Windchill system to an existing Windchill System? Just checking that this is not an upgrade or rehost.
Thanks for the reply.
Yes, I have started using WBM suite of tools(Extractor, Staging DB, Loaders and Validators) for this WC2WC migration. I found out the way to extract the metadata of EPMDocument, WTDocument's, but I am unable to populate the contentmetadata table (in staging) with primary content & secondary attachments details of those objects.
This is not an upgrade or rehost.
