File extensions stripped
I just did an installation of Windchill 11.0 M030 CPS16 on a Windows Server 16 OS.
When I went to look in some of the folders, all of the files have lost their file extensions and are lists as just a file.
Example: dsjavaproperties does not have the .bat on the end and when run, none of the commands in the file execute as the OS does not recognize the commands in the file. Renaming the file to dsjavaproerties.bat shoes it now as a Windows Batch file, but it still gives errors when executed.
Has anyone else had this issue with Windows Server 2016? The install works fine on Windows Server 2012.
How do I fix this without removing and reinstalling everything?
