For a Part, how to set the Default Downstream Location i.e. Folder Location where the Downstream view is to be created
  • May 15, 2017
  • 2 replies
  • 7192 views
Folder structure for our product:
Design
Manufacturing
Design Engineer creates part in Design Folder.
MBOM Creator open the part in Manufacturing Associate Part Structure Browser (MPSAB) and then creates a New Downstream Branch of the part. The default location for this is /Default of the Product which can be changed manually by browsing to required location.
We want to change this Default location to /Default/Manufacturing.
Please suggest steps.
It is controlled by a preference.
If you like, you can also write a delegate that uses a logic for number, location and so on.
prathi1-VisitorAuthor
Hi Binesh,
We already tried that preference. This preference sets a fixed location for creation of Downstream parts i.e a folder where downstream parts from all the products will be stored. What we need is that Downstream parts of each product should be stored in the Manufacturing folder of that particular product itself.
Prasad
Hi Prasad, I know it is not easy to set this preference in each of the products. I think writing your own delegate overriding DefaultDownstreamLocationDelegate is the elegant. I wish this is more configurable
PFB custom delegate to achieve this functionality,
public class MyCustomDelegateLocation extends DefaultDownstreamLocationDelegate{
  private static final String LOCATION_PATH_SEPARATOR = "/";
        @Override
        public STAInitialLocationValueBean getSTAInitialLocationValueBean(List<ObjectReference> refs){
  //Returns the location of the passed objects
        STAInitialLocationValueBean locationBean = new STAInitialLocationValueBean();
         for (final ObjectReference ref : refs) {
             WTContained persistable = (WTContained) ref.getObject();
             final Identifier associative_identifier = EntityUtils.toIdentifier(persistable);
             if (persistable instanceof Associative) {
    locationBean.addFolderIdForLocation(LOCATION_PATH_SEPARATOR + persistable.getContainerName(),Manufacturing)
                locationBean.addInitialLocationForAssociative(associative_identifier, LOCATION_PATH_SEPARATOR + persistable.getContainerName());
        return locationBean;
Thanks and Regards,
Thiagarajan
Hello Thiagarajan,
We tested this example but unfortunately the code is not working properly. Did you test it or adjusted it? Is it working at your system? If yes, can you share the working code?
See this article: https://www.ptc.com/en/support/article/CS278477
Maybe that helps you further.
