Get information from Windchill
  • December 28, 2011
  • 2810 views
hi everybody,
im a developer from mexico, in me work habe a one system in oracle that contains many informatino about the parts information but the drawings, changes and other things its in windshill, i want to know if its possible to get information form windchill and work wiht this in other data base or environment.
thanks.,.........
Hi Armando...
I can think of a couple of ways to do this "semi-automatically". However, I think to access Windchill data and use it in other (downstream) applications, you'll want to research Info*Engine. Here's a link to get you started. After reading it, let me know if you think this sounds like what you need.
http://www.ptc.com/WCMS/files/57292/en/5074_WC_InfoEngine_DS_EN.pdf
Thanks!
-Brian
Larry21-VisitorAuthor
hi, morning this is waht i need, i want to download information to one server in the company from windchill and work with this information, so i think the Windchill Info Engine Java Adapter (kit) works for me, do you have more information about this software?
Hi Armando...
As much as I'd love to be a Java developer, too... I've never been able to play with the Infor Engine Java Adapter. Hopefully someone else can answer this question or direct you to an appropriate thread or resource for more information. At least you know what product you're after. If no one responds, at minimum you can always contact PTC for a demonstration of the software. They are also usually pretty good about facilitation a discussion with a knowledgable support person or "expert" to get you started.
Thanks... and good luck!!
-Brian
