I'm trying to use alias attribute to dsiplat some informations from a promotion request as attributes on a document.
I got to display the promotion request number and the promotion date using alias attributes, but I also need to display the user that aproves this promotion request.
For date and number promotion request, I use the following mapping:
roleBObject@wt.maturity.PromotionTarget~roleAObject^wt.maturity.PromotionNotice~promotionDate
roleBObject@wt.maturity.PromotionTarget~roleAObject^wt.maturity.PromotionNotice~number
But for approver, I use the following mapping but no value is displayed:
roleBObject@wt.maturity.PromotionTarget~roleAObject^wt.maturity.PromotionNotice~roleBObject^wt.workflow.engine.WfVotingEventAudit~workCompletedBy
If anyone could provide some support, I would appreciate it.
Wesley
Hi @wneves,
I am currently working on the same process. May I know if this solved your issue since it is not working for me. Your help would be greatly appreciated.
Hi @rbhoraskar,
Thank you for your time. I have solved this issue few days ago.
You can mark this Topic as solved then.
No one will reply after that 🙂
Cheers,
Rahul
