How to Customize Affected Objects View Table
i need to add an editable Additional Comments column to Affected Objects table to be used in Problem Report and Change Request.
How do i do that?
1. created new attribute called ADDITIONAL_COMMENTS
2. added to Affected Activity Data type, wt.change2.AffectedActivityData.
3. i updated the com.ptc.windchill.enterprise.change2.change2clientResource.java with the following:
@RBEntry("Additional Comments")
@RBComment("Label to be used in the Table Views")
public static final String CHANGE_LINK_DESCRIPTION2 = "CHANGE_LINK_DESCRIPTION2";
4. updated the wncWeb.jar file
- what else do I need to do??
- I want to make this attribute editable while adding parts to Affected Objects. Right now, it does not allow to do so.
The only OOTB attribute it Comments is editable.
