How to add a user to a Problem Report role via code in Workflow
Ben_A
Through code inside the Workflow, I am able to get a specific user's object by querying their email address. I need to add that user to the Customer Role of the Problem Report so that they will be included in future tasks and notifications. So far, I haven't found any examples of this.
How do I programmatically add a user object to the Customer role of a problem report? Here is the code I has so far which runs in an expression robot:
String requester_query = "mail=me@gmail.com";
wt.org.DirectoryContextProvider dcp = wt.org.OrganizationServicesHelper.manager.newDirectoryContextProvider((String[])null,(String[])null);
java.util.Enumeration users = wt.org.OrganizationServicesHelper.manager.queryPrincipals(wt.org.WTUser.class, requester_query, dcp);
while (users.hasMoreElements()) {
    wt.org.WTPrincipal principal=(wt.org.WTPrincipal)users.nextElement();
    //principal is the user object that I need to assign to the customer role
    //verify the user was found
    displayName = principal.getPrincipalDisplayIdentifier();
    System.out.println ("Principal Display Identifier - " + displayName);
//Add to customer role?
ANNA_02
(To:Ben_A)
@Ben_A  Refer this article,
https://www.ptc.com/en/support/article/CS197690
https://www.ptc.com/en/support/article/CS138084
Role customeRole = Role.toRole("CUSTOM ROLE NAME");
if(customeRole !=null){
wt.team.TeamHelper.service.addRolePrincipalMap(customeRole, principal, team);
ANNA_02
(To:Ben_A)
Ben_A
(To:ANNA_02)
@ANNA_02Thank you for the example and links. I ended up using team.addPrincipal instead but I could not have found it without your help.
//In this example I'm adding the Problem Report's creator to the Customer role. If the role does not currently exist in the team, it is added automatically.
wt.change2.WTChangeIssue pbo =(wt.change2.WTChangeIssue)primaryBusinessObject;
//The role indicated in the following line must be the internal name for that role. For Customer, it is all upppercase.
wt.project.Role customerRole = wt.project.Role.toRole("CUSTOMER");
wt.team.Team team = (wt.team.Team)pbo.getTeamId().getObject();
wt.org.WTPrincipal principal = pbo.getCreator().getPrincipal();
team.addPrincipal(customerRole, principal);
