How to add version column to folder view in a projectlink project
  • June 1, 2020
  • 1951 views
Is it possible to add a "version" column to the folder view in projectlink projects?
Best answer by ScottMorris
In Windchill 11.1 there is a table view named All - including hidden objects that contains the version column. You can definitely create a new table view and add the version column to it.
Thank you so much!
The "all-including hidden objects" certainly works (I had not seen that before, thank you)
When I attempted to make a custom view before posting this question I had checked the 'folder' box on the 'object type' step of the custom view creation.  When I did that, it did not show 'version' as an available column to add.  Your post made me go back and try to create the custom view again, this time I checked 'document' and unchecked 'folder' on the object type tab, and now the 'version' is an available column I could add and that worked too!
