Hello
I want to save the Jconsole's log because windchill stopped sometimes.
Our PLM Enginner says 'this problem is about to Heap Memory size. Out of memory'
So, I want to monitor heap memory usage with Jconsole.
But I can't find the Jconsole's Log Auto Save function.
How to Auto Save the Heap Memory Usage log?
I would not spend your time right now monitoring those logs if you know you are having memory issues. I recommend tuning your system to prevent it from happening in the first place:
https://www.ptc.com/en/support/article/CS153338?source=search
Assuming you have enough resources dedicated to the system, you need to make some parameter changes and allocations. The WCA can make recommendations.
Hi @HK_10285495,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
