How to enable Manual entry of revision on document creation page in Windchill?
  • November 18, 2014
  • 4 replies
  • 1797 views
How do I override Revision while creating the document in Windchill? User should be able to enter the Revision on the creation page of the document. Can any one assist me please?
Just a heads up, I've moved this discussion into our community so that others can chime in.
It depends on your lifecycle template. Assuming the starting state is 'In work', if the template allows revise from 'In Work' to 'In Work', then you can change the revision before ever uploading or checking in. If instead you only allow revise from 'Released' (or whatever you are calling it), then you have to check in first, then release, then revise to the intended target revision.
I think there is a product idea somewhere requesting the ability to set revision at object creation.
22-Sapphire I
November 19, 2014
Thankyou All,
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS127643
The above given link helped me to solve my request. Thankyou verymuch.
