How to get latest revision of a document using Rest API ?
Level 8
I am using Windchill 11.1 M010.
I want to get latest revision of a document using Rest API.
I tried to use filter,
$filter : latestiteration eq '1',
but, this gives "Invalid expression".
Is there any way to get the latest revision of a document through Rest API?
Re: How to get latest revision of a document using Rest API ?
I got this tip from one of my Windchill colleagues...
Can you try with
"Latest": true
instead of latestiteration : 1?
but,
This also doesn't work. It says "Latest" is Invalid property
Could you please post the complete request here?
Including any headers for Post, that contain any additional parameters.
This might help in seeing if there's anything off in the request itself.
below I am sharing my Javascript code. In this code, I am passing typeID, and properties (attributes),  also in a $filter I am setting criteria, so there I want to set a filter to fetch only latest version documents.
var params = {
type: 'GET',
url: me.getRestUrl() + "/structure/objects",
queryParams: {
'$select': properties,
'$filter': "endswith(number ,'"+number+"') and state eq 'Released' ",
'navigationCriteria': navigationCriteria,
'typeId': selectedTypeId,
// result: JSON
var jsonResult = me.processJSONRequest(params);
I tried with,
$filter : "latestIteration eq '1'",
but this displays all the version of a document. eg. A.1 and B.1 and B.2
I only want to fetch the latest i.e B.2
@mneumann did you got my question?
@shindemayur
yes, but unfortunately I can't help you here.
Someone from the Windchill Customization team might - you might have to open a Support Case for this one.
ok, Thank you.
