How to make use of ExportPrefTables in Windchill
  • June 21, 2015
  • 2 replies
  • 1327 views
Hi there,
the CS195211 discusses about Exporting Performance tables, I would like to know how to make use of this? Is there any tool required for opening exported files?
Shashi
Best answer by BineshKumar1
The tables which you export from this utility are available for you to view and interrogate through the server status monitoring tools. The export utility is a way to export the performance tables in a database neutral format, so that TS can import it in their system to investigate performance issues.
Binesh
Barry Wehmiller International
Binesh
Thanks Binesh
