How to pass NavigationCriteria or setConfigSpecs in Query-Tree webject
  • September 25, 2023
  • 2131 views
HI all,
I am navigating part usage link of a part and I would like to add configspec into Query-Tree webject. What is the syntax for adding NavigationCriteria  or configSpec?
HelesicPetr
Hi @gmydoor-2
Show example what you are trying to do.
PetrH
gmydoor-210-MarbleAuthor
Hi @HelesicPetr
I am passing top part ( parent part) to below webject and fetching child components. In my part structure, child component present is "As designed" view. But since the latest version of this child part in in Manufacturing view, below webject is fetching me Manfacturing view. Ideally i need to get "As designed" view. I assume this can be achieved by config spec. What will be the syntax to pass config Spec in a webject?
<ie:webject name="Query-Tree" type="OBJ">
<ie:param name="INSTANCE" data="$(@FORM[]supporting-adapter[*])" delim="!" valueSeparator="!" default="<%=com.infoengine.au.NamingService.getVMName()%>"/>
<ie:param name="ATTRIBUTE" data="obid,number,name,view,variation2,versionInfo.identifier.versionLevel,iterationInfo.identifier.iterationId" delim=","/>
<ie:param name="GROUP_IN" data="parts"/>
<ie:param name="TYPE" data="wt.part.WTPartUsageLink"/>
<ie:param name="DEPTH" data="${FORM[]depth[]}" default="100" />
<ie:param name="DIRECTION" data="uses"/>
<ie:param name="OUTPUT_TYPE" data="FULL"/>
<ie:param name="MODE" data="FLAT" />
<ie:param name="GROUP_OUT" data="tree"/>
</ie:webject>
HelesicPetr
Hi @gmydoor-2
Does this help page can help you?
Query-Links
it seams that you can define some custom configSpec by code and use it in the ie:webject
PetrH
