How to share published PDF drawing outside of organization without creating duplicate or sharing CAD
Version: Windchill 12.1
Use Case: How to Publish the PDF drawing with water marking and store it has separate Drawing document in Windchill instead of saving it has the association of CAD drawing ?
Description:
We are in the process of implementing the CAD Publisher and intention was not to create manual PDF drawing to reduce the user effort and add water marking to it.
Problem raises when the sharing the drawing with supplier, we do not want to share the CAD drawing outside the organization, but the published PDF drawing with water Marking will be association of CAD drawing and we do not want to duplicate the file while sharing through the ProjectLink.
How to Publish the PDF drawing out of CAD drawing and store it has separate Drawing document in Windchill ?
thanks in advance for all your suggestions!!!
