How to skip or exclude versions from default versioning schemes in Windchill PDMLink 11.0 M030
  • December 19, 2018
  • 2 replies
  • 2936 views
How to skip or exclude versions from default versioning schemes in Windchill PDMLink?
Below steps does not work:
  1. Edit wt.properties
          wt.series.MulticharacterSeries.MilSpec.skipList=CIOQSXZ2
      2. Restart Windchill
      3. Revise WTDocument does not skip C
below is the OIR file of WTDocument
<AttrValue id="MBA|versionInfo" algorithm="com.ptc.core.foundation.vc.server.impl.VersionInfoGenerator">
<Arg>wt.series.HarvardSeries</Arg>
</AttrValue>
Did you create a NEW document and then try to skip rev C?
The revision scheme is 'attached' to the document once it is created by the OIR. Changing the OIR will only work on new documents created after the change.
Cassie15-MoonstoneAuthor
Hello Ben,
Thanks for help.
Yes, it is new Document
Hi , Between  the belwo steps , have you run an xconfmanager -p  , to propagate the changes to the site.xconf file ?
