I NEED TO RUN Creo3 and wildfire 5 with windchill 11 and 9.1
  • September 15, 2016
  • 2 replies
  • 3129 views
hAS ANYONE EVER BEEN SUCCESSFUL IN USING CREO3 WITH WINDCHILL 11 AND
WILDFIRE 5 WITH WINDCHILL 9.1 ON THE SAME COMPUTER AND THE SAME USER@
Best answer by mdebower
I found a Tech Support Article that explains the steps: Document - CS62457
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS62457&source=Article%20viewer
Note that you will need an active PTC support account to access it.
Should be possible since Windchill is not running on the same computer as the CAD software.
Use different shortcut icons to Wildfire 5 and Creo 3, each pointing to their own cache file folders.
Then register each CAD program to its respective Windchill server.
Minimum 3 computers required, 2 servers and 1 workstation. Realistically it would be 5 computers, 2 Windchill/Apache servers, 2 dadabase serevrs and your 1 workstation.
ahavassy1-VisitorAuthor
‌Ben, thanks for that answer there is one issue and that is how do you set up a seperate cache location for each cad instance. I have never had much luck with doing that but maybe I was doing that wrong.
Use different Start-In folders for each version and then it is automatic since the WF_Cache is placed in the starts-in folder. It only becomes complicated when you use the same start-in folders, then you need to use a config.pro setting to set the cache.
Also do NOT use a common config.pro since many settings have changed/ been obsoleted/added between Wildfire 5 and Creo 3.
mdebower18-OpalAnswer
18-Opal
September 16, 2016
‌aawesome this is perfect exactly what I needed
