Hello PetrH,
I have a similar requirement.
I have two Global attributes "Attribute_A" & "Attribute_B" on Drawing (EPMDocument), i want to make sure that when drawing is get published, this two attributes will be displayed in Title Block of Drawing.
Can you please help me here, how to achieve this ? any input will be helpful.
Thanks and Regards,
Vivek
Hi @VU_10827294
The easiest way is to create a pre checkin listener
It can control if the CAD Document drawing has defined your two attributes .
Throw an exception.
PetrH
Can you describe your use case a little more?
You can update your drawing format to include the title block, and in that title block, display the required attributes.
Another potential solution would be watermarking. It's possible to include attributes as a watermark that gets added during publishing.
