I am using Windchill Enterprise Systems Integration Release 11.1 and Datecode with CPS M020 CPS30
Our requirement is to release part and BOM to ERP through a change process(Promotion Request), but if we release the WTDocument/EPMDocument individually through the change process RTM workflow triggers.
How to release only parts/BOMS to ERP(RTM workflow needs to be trigger) using the change process. If we release the WTDocument/EPMDocument through a change process RTM workflow won't be trigger. Help us to configure this issue.
Any preference settings to avoid publishing WTDocument/EPM Document to ERP.
There are dozens of preferences that can be set for the ESI configuration.
If we remove the Promotion Request Configuration Specification State to Empty and Change Notice Centric State to Empty, only Lifecycle States Triggering Publication of a Document and Lifecycle States Triggering Publication of a CAD Document set to "RELEASED"
if we set the preference settings like this, when we do the change process for WTDocuments/EPM Documents RTM workflow won't triggers, and it will works, but if we release the part/BOM through change process, in that case RTM workflow won't triggers,it only triggers for set state.
how to launch the RTM workflow automatically while publishing the part/BOM through change process not for EPM Document / WT Document
