Increase the character length for add participant tab.
  • April 2, 2024
  • 1522 views
Increase the character length for add participant tab.When we are searching in add participant tab it is maximum taking 200 character which is a 00TB functionality as per PTC and cannot be changes. We are in Windchill 11.1.
You need to search on more than 200 characters????
HelesicPetr
Good point @BenLoosli ,
I can not imagine that a user's name could be longer then 200 characters.
PetrH
My guess is a semicolon separated list of usernames.
{username1};{username2};{username3};...
The workaround for that scenario is to dump the full string of usernames in Notepad++ and split the list so that each search string is less than 200 characters.  Then search one line of usernames at a time.
Seems a lot easier than trying to change Windchill to accept longer search strings.
FYI: That is also what the knowledge base article recommends.
https://www.ptc.com/en/support/article/CS412991
