18-Opal
November 13, 2017
Is SQL Server included in PSI?
  • November 13, 2017
  • 1553 views
Hi i'm seonho
We are re-reading the Windchill Installation Guide.
Or should I install it separately?
thanks
Best answer by TomU
Yes, either Oracle or SQL Server needs to be installed and configured prior to installing Windchill.
You probably should read through the installation guide and other related documents.
https://support.ptc.com/WCMS/files/168349/en/WCInstallConfigGuide.pdf
It is not included in the PSI.
CHASEONHO18-OpalAuthor
18-Opal
November 14, 2017
should i installed SQL Server?
before i installed windchill,I have not installed SQL Server separately.
TomU23-Emerald IVAnswer
