Hello. I am currently attempting to create a Cog nos report that allows a user to select multiple contexts with a select and search prompt with multi select and pass them back as parameters for a Query Builder report, however when I try to I can only seem to pass the first selected value in the list. Is there a way to pass them all back as a Comma separated values?
Dbellisario,
Perhaps you are looking for this?
https://www.ptc.com/en/support/article/CS59991
I would suggest opening a Support case if not, so that one of the engineers who specializes in Cognos reports might be able to assist or confirm this with you.
Hi Michael,
Unfortunately that wont work. Its not the passing of attributes from Cognos to Windchill the problem. Cognos cant seem to send a comma separated parameterized string to Windchill from a multi-valued search and select prompt. It only sends the first value. It looks like TS is the route to go. Thank you for your assistance.
