8-Gravel
January 12, 2026
Is there a way to restrict publishing of CAD models having specific keyword in the name
  • January 12, 2026
  • 2 replies
  • 86 views
Version: Windchill 13.0
Use Case: We want to restrict publishing of some CAD models having specific keyword in the name. These jobs whenever they reach the CAD worker for publishing it crashes the worker.
Description:
Is there a way to restrict these models from getting to worker.?
avillanueva
23-Emerald I
23-Emerald I
January 12, 2026
Sure with customization. Perhaps a better way is to use searches to ID them, then add them to the do not publish list.
BikrantS8-GravelAuthor
8-Gravel
January 13, 2026
Please could you provide little more details on how to do it.
Publish and Thumbnail Control can be used to limit publishing of certain files.
8-Gravel
January 13, 2026
Please could you provide little more details any reference documentation or steps will help.
Hi @BikrantS
How many number objects are currently present?
Will any additional objects be created in the future using this specific keyword?
If the number of objects is limited (around 50–100) and no additional objects will be created in the future, it can be managed through publish and thumbnail control.
However, if there are a larger number of objects, it should be controlled using publish rules.
