Is there an OOTB function to limit the repeated creation of control features?
  • October 17, 2024
  • 408 views
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.5
In the BOM converter, when selecting annotation information from the visualization and creating control features, sometimes multiple will be created when one is selected;
The same annotation can repeatedly create control features. Is there a standard function to limit it?
Translated by the moderation using Google Translate
在BOM变换器中,从可视化选中注释信息,创建控制特征时,有时选中一个,会创建出多个;
同一个标注,可以重复创建控制特征,是否有标准功能可以限制;
Catalina
Community Moderator
October 21, 2024
Hi @TA_8923098
Thank you for your question!
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina | PTC Community Moderator
