6-Contributor
June 30, 2023
ListUnreferencedFiles - when I run WINDU Task I got below error,
  • June 30, 2023
  • 1292 views
ListUnreferencedFiles:
Diagnostic task computes the storage space occupied by unreferenced files in the system. To remove these unreferenced files from the system, follow the instructions provided in the "Maintaining Your Vaults" section of the Windchill System Administrator's Guide.
can you guide me step by step on how to remove un referenced files
Tue 6/27/23 18:55:35: at java.lang.Thread.run(Thread.java:745)
Tue 6/27/23 18:55:35: Task failed.
Tue 6/27/23 18:55:35: com.ptc.windchill.upgrade.updates.UpdateExecutionException: Error executing IncrementalUpdate Unreferenced Files Report (#ListUnreferencedFiles)
Tue 6/27/23 18:55:35: Nested exception is: (com.ptc.windchill.upgrade.updates.directives.directivesResource/39) com.ptc.windchill.upgrade.updates.DirectiveExecutionException: Method server code wt.fv.ListUnreferencedFilesDT.executeDiagnosticTask failed. See nested exception for details
Tue 6/27/23 18:55:35: Nested exception is: (wt.pom.pomResource/10) wt.pom.PersistenceException: A commit cannot be done when a rollback is in progress. The following is the rollback stacktrace.
Tue 6/27/23 18:55:35: ROLLBACK: java.lang.Thread.getStackTrace(Thread.java:1589)
Best answer by Marco Tosin
Below text taken from article
Article - CS294987
[Knowledge hub] About "Remove Unreferenced Files" in Windchill
Applies To
  • Windchill PDMLink 10.2 to 12.0
Description
  • Knowledge summary about Remove Unreferenced Files (RUF) utility
    • What is the function of Remove Unreferenced Files utility
    • How to safely use Remove Unreferenced Files utility
Resolution
Marco Tosin
Many of the user questions are matched by PTC support articles with possible answers.
You can start from here https://www.ptc.com/en/support/search
And this is the answer
[Knowledge hub] About "Remove Unreferenced Files" in Windchill PLM
Marco
HelesicPetr
@Marco_Tosin
Your link is blocked by my browser I don't know why 😄
Link to the article CS294987
PetrH
Marco Tosin
Article - CS294987
Applies To
Description
Resolution
Marco
