Loading EPM documents (DITA) into Windchill
  • June 17, 2024
  • 2 replies
  • 1492 views
Looking for a way to upload and download DITA files into Windchill that does not require Arbortext.
Fadel
23-Emerald I
June 18, 2024
what's about uploading them as WTDocucment (xml content )
Buiꓘa
Community Manager
June 24, 2024
Hi @DG_9924912,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
I still don't have an answer on how to load a dynamic document (DITA XML) without using Arbortext.
Isn't there an ACL that would allow me to load a file in a specific library?  We are trying to load an XML document into a database...
You would set up an ACL for a "Document".  Then you would upload your XML as a document.  You can either browse for it or you can drag and drop it in.  If this isn't what you are looking for, then you need to describe what you are looking for better.
Setup Document ACL:
Create a New Document:
Choose type of Document:
Browse for or drag and drop document:
Thank you,
Brian
