This is the only statement I can find, and it doesn't seem like it's talking about the same thing. None of the Matrices mention a Windows version. This would be for publishing Creo 4.0+ and SolidWorks 2017+ with Windchill 11.0. The current setup is using Creo Adapters 4.0 on a Windows 7 machine.
Seems odd that the MCAD Adapters Install Guide doesn't show which versions of Windows are supported for a separate publishing system.
This must be what you are referring to
I saw that but obviously wasn't understanding how to interpret the info.
Thanks!
It means that all the operating systems listed in the table are supported for Creo View Adapter 4.0, except Solaris.
