Monitoring database host using PTC System Monitor
I'm using Windchill in our environment. Currently testing PSM 6.0 to monitor environment. Things are working as expected so far though I still need to learn more on administration of PSM. Question is how can I monitor database host of Windchill?
Since I installed PSM agents in Windchill application server, the agents are also monitoring properties of host like CPU, Memory, etc. I am able to add database connection in PSM and thus monitor transactions, but how can I monitor host properties of database server as well?
Thank you,
