Not able to view the Image/Thumbnail properly in Team Center visualization using PLM XML
  • May 4, 2023
  • 1094 views
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.2
Basically, We have a CAD Assembly with small structure around 4 child parts. Each Part having their own representation and when we click on some custom button, one .plmxml file will be download with the Location tag where the every JT file has been placed for the CAD object.
meaning: Under 001.Asm, I have 002.prt, 003.prt and 004.prt. When I click on custom button, XML file will be download and when I Open my root asm JT file, the Image is absolutely opening fine in Creo side. But, when I tried to open the PLM XML in Team Center visulization tool, the Image is not showing properly. So, what is the best way to configure it.
Here are the errors that I faced
NA
So, the Creo and Windchill end seemly work fine (i.e. the visualization is getting generated and you open the JT file on the Creo end) but then you go to TeamCenter and things don't show up?
Honestly, it sounds like a better question for the Siemens TeamCenter community page (here).
Not knowing what errors you're seeing or how the image is not showing properly it's hard to say. Could be something trivial in the .xml that TeamCenter is expecting to see differently than Creo does?
