Number count of prt, asm, & drw files in Windchill 11.2.1.0
  • June 22, 2022
  • 2 replies
  • 3853 views
Is there a fast, easy way to get the exact number of only the latest revisions of every prt, asm, & drw files in Windchill 11.2.1.0?   This is actually Intralink 11.2.1.0 which we are planning to upgrade soon.
Joe S.
Best answer by RandyJones
Since you only want know the number of latest Revisions you can simply query the epmdocumentmaster table:
select count(*) Num_Prts from epmdocumentmaster where cadname like '%.prt';
select count(*) Num_Asms from epmdocumentmaster where cadname like '%.asm';
select count(*) Num_Drws from epmdocumentmaster where cadname like '%.drw';
avillanueva
23-Emerald I
23-Emerald I
June 22, 2022
Easiest is write a SQL query and look at the EMPDOCUMENT table. There is a column which indicates if it is the latest iteration of a particular version. Do you have access to run queries against DB?
jschutte10-MarbleAuthor
I have full access to the server.  However, I have no clue how to write or run a SQL query.    I actually suspected this would be the recommendation.  I was hoping that there was a tool somewhere in Windchill I could use.
Any suggestions on how to write & run this query?
Thanks Randy.   I attempted to run just that first line for the .prt & this is the error I got:
The term '*' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
Thanks everyone who replied.   Problem solved.   This reminded me of our old user group!
-joe
