Only new users can't check out objects
yinjin
Would you please help on my Korea customer’s new user can't  checkout objects issue ?
Customer environment : 10.2M030CPS10 windows OS (dev server)
Issue : All new created user can’t check out  WTDocument and WTParts with below error .
Checkout failed with below error
The cabinet could not be found. Container: "Site" Cabinet name: "xxxxx"
 check out error
TS done :
1.Added full control permission but still failed check out
2.Follow the https://www.ptc.com/en/support/article?n=CS19027
     Run Winru -Fix CabinetBased Data Container Alignment  and Windu -CabinetBasedDataContainerAlignment
But still cant resolved the issue
In DB, found that all new created userss  classNameKeyContainerreference values  is  Wt.pdmlink.PDMLinkProduct  IDA3CONTAINERREFERENCE  85020
Normal user’s classNameKeyContainerreference values  is wt.inf.container.ExchangeContainer  IDA3CONTAINERREFERENCE is 5.
So try  replace new user’s  classNameKeyContainerreference and IDA3CONTAINERREFERENCE
To  wt.inf.container.ExchangeContainer and 5 then all new created users can able check out all objects.
Does anyone have similar experience or suggestion the issue ?
CLASSNAMEKEYCONTAINERREFEREN
NAME
5
yjpark
5
yhpark
5
dwkima
5
bhson
5
swma
5
jwsong
5
smkim
5
msjeong
5
tien.ng
5
ohyama
5
hoanghuy
5
lem.nv
wt.pdmlink.PDMLinkProduct
85020
ptcuser001
85020
ywchoi
85020
dykimb
85020
kwkimb
85020
htkim
85020
jcum
85020
cjyun
85020
jmbae
85020
gwchoi
85020
twkim
85020
jsleea
85020
kpkim
Akim
Vincent-Kulak
(To:yinjin)
You have opened case support about that ?
EDIT:
You are a PTC employee ( Sorry i did not see it immediately).
Why you post on community and not request your R&D ? ( I see several post from TS Engineer )
