Oracle access manager with Windchill help needed.
  • August 11, 2017
  • 4731 views
 We are currently in process of setting up OAM with Windchill, could you please let me know if you were able to successfully implement ? If so is it possible to share the configurations need to be done from Windchill side and OAM side ?
              Currently we did configure the OAM for a POC work but doesnt seems to be working. When we enable OAM we are getting user not found from Corporate LDAP, if we disable OAM the user seems to have got it authented.
Baalajee.T
Hi Baalajee,
How are you integrating Apache with OAM? Are you using webpass? If you are using webpass, you should set the user header variables in your OAM so that the tomcat recieves the logged in user name. By the way, where are you getting the "User not found" error is it in the Apache logs or in the webpage after the login
bt_011-VisitorAuthor
Thanks for the response, at the moment the OAM team is different from the application team and hence i m not sure on the configuration.I will check and let you know, from the Windchill side is there any settings that we need to make it enabled ?
I m getting the error when trying to give the credentials from UI. We are using Webgate for this.
HI Binesh,
             We use webgate for integration Apache with OAM. User headers are being set for the same. Is there any specific header name which needs to be set ? Syntax etc ?.
Baalajee.T
