How can I get the publisher to create our pdfs without having the planes, axes, points visible? Also our cable drawings do not show the thick lines.
I tried setting the options and saving the config.pro file with the setting I want but that didn't work. Does the publisher read it's own config.pro or the default location file?
Got it! I had modified the config.pro like I was supposed to, but did not restart the worker.
