PSI for Oracle configuration is hung
I am building a test system for Windchill 11.0.
Install Oracle 12c. Run the 11.0 PSI Setup to configure Oracle.
It has been running for almost 12 hours and is stuck at 21% complete.
No user problem,no permission problem,
I try to kill the process and start over with a clean Oracle install and then rerun the PSI Setup.
But the completion rate is still only 21%.
