PTC Solution Installer stays blocked
Hello, I downloaded the PTC Solution Installer for Windchill 13. I'm running the installer on Linux CentOS 9 Stream + Java 17, for somewhat reason, the installer gets blocked on the first step:
"Please wait, PTCSolnInstaller is being configured for your system. This may take a moment"
Stays like that until I close it.
When I go to the /tmp directory I see that the installer creates a install.dir folder. Inside the temp.lax file I see a message:
"The installer either could not find a Java VM, or the Java VM on this system is too old. The installer requires Java 1.1.5 or later. It can be downloaded from -java.sun.com/products/jdk/1.1/jre/".
The strange thing is I have Java already installed. Any idea why it cannot find the JVM or it's something else?
